man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_inquire_mechs_for_name(3GSS)
Name
gss_inquire_mechs_for_name - list mechanisms that support the specified name-type
Synopsis
cc [flag …] file–lgss [library …]
#include <gssapi/gssapi.h>
OM_uint32 gss_inquire_mechs_for_name(OM_uint32 *minor_status,
     const gss_name_t input_name,gss_OID_set *mech_types);
Description
The gss_inquire_mechs_for_name() function returns the set of mechanisms supported by the GSS-API that may be able to process the specified name. Each mechanism returned will recognize at least one element within the internal name.
Some implementations of the GSS-API may perform this test by checking nametype information contained within the passed name and registration information provided by individual mechanisms. This means that the mech_types set returned by the function may indicate that a particular mechanism will understand the name, when in fact the mechanism would refuse to accept the name as input to gss_canonicalize_name(3GSS), gss_init_sec_context(3GSS), gss_acquire_cred(3GSS), or gss_add_cred(3GSS), due to some property of the name itself rather than the name-type. Therefore, this function should be used only as a pre-filter for a call to a subsequent mechanism-specific function.
Parameters
The parameter descriptions for gss_inquire_mechs_for_name() follow in alphabetical order:
minor_status
Mechanism-specific status code.
input_name
The name to which the inquiry relates.
mech_types
Set of mechanisms that may support the specified name. The returned OID set must be freed by the caller after use with a call to gss_release_oid_set(3GSS).
Errors
The gss_inquire_mechs_for_name() function may return the following status codes:
GSS_S_COMPLETE
Successful completion.
GSS_S_BAD_NAME
The input_name parameter was ill-formed.
GSS_S_BAD_NAMETYPE
The input_name parameter contained an invalid or unsupported type of name.
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Safe
See also
gss_acquire_cred(3GSS), gss_add_cred(3GSS), gss_canonicalize_name(3GSS), gss_init_sec_context(3GSS), gss_release_oid_set(3GSS), attributes(5)
Developer’s Guide to Oracle Solaris 11 Security
