man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_verify_mic(3GSS)
Name
gss_verify_mic - verify integrity of a received message
Synopsis
cc [ flag... ] file... –lgss  [ library... ]
#include <gssapi/gssapi.h>
OM_uint32 gss_verify_mic(OM_uint32 *minor_status,
     const gss_ctx_id_t context_handle, const gss_buffer_t message_buffer,
     const gss_buffer_t token_buffer, gss_qop_t *qop_state);
Description
The gss_verify_mic() function verifies that a cryptographic MIC, contained in the token parameter, fits the supplied message. The qop_state parameter allows a message recipient to determine the strength of protection that was applied to the message.
Since some application-level protocols may wish to use tokens emitted by gss_wrap(3GSS) to provide secure framing, the GSS-API supports the calculation and verification of MICs over zero-length messages.
Parameters
The parameter descriptions for gss_verify_mic() follow:
minor_status
The status code returned by the underlying mechanism.
context_handle
Identifies the context on which the message arrived.
message_buffer
The message to be verified.
token_buffer
The token associated with the message.
qop_state
Specifies the quality of protection gained from the MIC. Specify NULL if this parameter is not required.
Errors
gss_verify_mic() may return the following status codes:
GSS_S_COMPLETE
Successful completion.
GSS_S_DEFECTIVE_TOKEN
The token failed consistency checks.
GSS_S_BAD_SIG
The MIC was incorrect.
GSS_S_DUPLICATE_TOKEN
The token was valid and contained a correct MIC for the message, but it had already been processed.
GSS_S_OLD_TOKEN
The token was valid and contained a correct MIC for the message, but it is too old to check for duplication.
GSS_S_UNSEQ_TOKEN
The token was valid and contained a correct MIC for the message, but it has been verified out of sequence; a later token has already been received.
GSS_S_GAP_TOKEN
The token was valid and contained a correct MIC for the message, but it has been verified out of sequence; an earlier expected token has not yet been received.
GSS_S_CONTEXT_EXPIRED
The context has already expired.
GSS_S_NO_CONTEXT
The context_handle parameter did not identify a valid context.
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Safe
See also
gss_wrap(3GSS), attributes(5)
Developer’s Guide to Oracle Solaris 11 Security
