man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_indicate_mechs(3GSS)
Name
gss_indicate_mechs - determine available security mechanisms
Synopsis
cc [ flag... ] file... –lgss  [ library... ]
#include <gssapi/gssapi.h>
OM_uint32 gss_indicate_mechs(OM_uint32 *minor_status,
     gss_OID_set  *mech_set);
Description
The gss_indicate_mechs() function enables an application to determine available underlying security mechanisms.
Parameters
The parameter descriptions for gss_indicate_mechs() follow:
minor_status
A mechanism-specific status code.
mech_set
Set of supported mechanisms. The returned gss_OID_set value will be a dynamically-allocated OID set that should be released by the caller after use with a call to gss_release_oid_set(3GSS).
Errors
The gss_indicate_mechs() function may return the following status codes:
GSS_S_COMPLETE
Successful completion.
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Safe
See also
gss_release_oid_set(3GSS), attributes (5)
Developer’s Guide to Oracle Solaris 11 Security
