man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
sip_get_msg_len(3SIP)
Name
sip_get_msg_len - returns the length of the SIP message
Synopsis
cc [ flag ... ] file ... –lsip [ library ... ]
#include <sip.h>
int sip_get_msg_len(sip_msg_t sip_msg,
     int *error);
Description
The sip_get_msg_len() function will return the length of the SIP message sip_msg.
Return Values
For functions that return an integer, the return value is the specified value on success and -1 on error.
The value of errno is not changed by these calls in the event of an error.
Errors
This function takes a pointer to an integer error as an argument. If the error is non-null, one of the following values is set:
EINVAL
The input SIP message sip_msg or the header value is null; or the specified header/header value is deleted.
EPROTO
The header value is not present or invalid. The parser could not parse it correctly.
ENOMEM
There is an error allocating memory for the return value.
On success, the value of the location pointed to by error is set to 0.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
libsip(3LIB)
