man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
sip_hold_dialog(3SIP)
Name
sip_hold_dialog, sip_release_dialog - hold/release reference on a dialog
Synopsis
cc [ flag ... ] file ... –lsip [ library ... ]
#include <sip.h>
void sip_hold_dialog(sip_dialog_t dialog);
void sip_release_dialog(sip_dialog_t dialog);
Description
For functions that return a pointer of type sip_str_t, sip_str_t is supplied by:
typedef struct sip_str {
     char	*sip_str_ptr;
     int	sip_str_len;
}sip_str_t;
The sip_str_ptr parameter points to the start of the returned value and sip_str_len supplies the length of the returned value.
The sip_hold_dialog() function is used to hold a reference on the dialog. A dialog is not freed if there are any references on it.
The sip_release_dialog() function is used to release a reference in the dialog. If the reference in a dialog drops to 0 and it is in SIP_DLG_DESTROYED state, it is freed.
Return Values
The value of errno is not changed by these calls in the event of an error.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
libsip(3LIB)
