cc [ flag ... ] file ... –lsasl [ library ... ] #include <sasl/sasl.h> int sasl_setprop(sasl_conn_t *conn, int propnum, const void *pvalue);
Use the sasl_setprop() interface to set the value of a SASL property. For example, an application can use sasl_setprop() to tell the SASL liabrary about any external negotiated security layer like TLS.
sasl_setprop() uses the following flags.
External authentication ID that is a pointer of type const char
External SSF active of type sasl_ssf_t
User realm that is a pointer of type const char
sasl_security_properties_t, that can be freed after the call
A string that describes the local ip and port in the form a.b.c.d:p or [e:f:g:h:i:j:k:l]:port or one of the older forms, a.b.c.d;p or e:f:g:j:i:j:k:l;port
A string that describes the remote ip and port in the form a.b.c.d:p or [e:f:g:h:i:j:k:l]:port or one of the older forms, a.b.c.d;p or e:f:g:j:i:j:k:l;port
The SASL connection context
The identifier for the property requested
Contains a pointer to the data. The application must ensure that the data type is correct, or the application can crash.
sasl_setprop() returns an integer that corresponds to a SASL error code.
The call to sasl_setprop() was successful.
See sasl_errors(3SASL) for information on SASL error codes.
