man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
ldap_first_attribute(3LDAP)
Name
ldap_first_attribute, ldap_next_attribute - step through LDAP entry attributes
Synopsis
cc [ flag...] file... -lldap[ library...]
#include <lber.h>
#include <ldap.h>
char *ldap_first_attribute(LDAP *ld, LDAPMessage *entry,
     BerElement **berptr);
char *ldap_next_attribute(LDAP *ld, LDAPMessage *entry,
     BerElement *ber);
Description
The ldap_first_attribute() function gets the value of the first attribute in an entry.
The ldap_first_attribute() function returns the name of the first attribute in the entry. To get the value of the first attribute, pass the attribute name to the ldap_get_values() function or to the ldap_get_values_len() function.
The ldap_next_attribute() function gets the value of the next attribute in an entry.
After stepping through the attributes, the application should call ber_free() to free the BerElement structure allocated by the ldap_first_attribute() function if the structure is other than NULL.
Errors
If an error occurs, NULL is returned and the ld_errno field in the ld parameter is set to indicate the error. See ldap_error(3LDAP) for a description of possible error codes.
Attributes
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/library
Interface Stability
Committed
See also
ldap(3LDAP), ldap_first_entry(3LDAP), ldap_get_values(3LDAP), ldap_error(3LDAP), attributes(5)
Notes
The ldap_first_attribute() function alllocates memory that might need to be freed by the caller by means of ber_free(3LDAP).
