man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_release_oid(3GSS)
Name
gss_release_oid - release an object identifier
Synopsis
cc [ flag... ] file... –lgss  [ library... ]
#include <gssapi/gssapi.h>
gss_release_oid(OM_uint32 *minor_status, const gss_OID *oid);
Description
The gss_release_oid() function deletes an OID. Such an OID might have been created with gss_str_to_oid().
Since creating and deleting individual OIDs is discouraged, it is preferable to use gss_release_oid_set() if it is necessary to deallocate a set of OIDs.
Parameters
The parameter descriptions for gss_release_oid() are as follows:
minor_status
A mechanism-specific status code.
oid
The object identifier of the mechanism to be deleted.
Errors
gss_release_oid() returns one of the following status codes:
GSS_S_COMPLETE
Successful completion.
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT Level
Safe
See also
gss_release_oid_set(3GSS), gss_str_to_oid(3GSS), attributes(5)
Developer’s Guide to Oracle Solaris 11 Security
Warnings
This function is included for compatibility only with programs using earlier versions of the GSS-API and should not be used for new programs. Other implementations of the GSS-API might not support this function, so portable programs should not rely on it. Sun might not continue to support this function.
