man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
sip_create_dialog_req_nocontact(3SIP)
Name
sip_create_dialog_req, sip_create_dialog_req_nocontact - create an in-dialog request
Synopsis
cc [ flag ... ] file ... –lsip [ library ... ]
#include <sip.h>
sip_msg_t sip_create_dialog_req(sip_method_t method,
     sip_dialog_t dialog, char *transport, char *sent_by,
     int sent_by_port, char *via_param, uint32_t smaxforward,
     int cseq);
sip_msg_t sip_create_dialog_req_nocontact(sip_method_t method,
     int cseq);
Description
The sip_create_dialog_req() function creates and returns a SIP request with the state information contained in dialog. The method in the resulting request is from method. The method can be one of the following:
INVITE
ACK
OPTIONS
BYE
CANCEL
REGISTER
REFER
INFO
SUBSCRIBE
NOTIFY
PRACK
The resulting request line in the SIP message has the SIP-Version of “2.0”. The URI in the request line is from the remote target in the dialog or from the route set in the dialog, if present. See RFC 3261 (section 12.2) for details. The FROM, TO, and CALL-ID headers are added from the dialog. The MAX-FORWARDS header is added using the value in maxforward. The CSEQ header is added using the SIP method in method and the sequence number value in cseq. If cseq is -1, the sequence number is obtained from the local sequence number in the dialog. The local sequence number in the dialog is incremented and is used in the CSEQ header. The VIA header added is created using the transport, sent_by, sent_by_port (if non-zero), and via_param (if any). If dialog has a non-empty route set, the resulting SIP request has the route set from the dialog.
The sip_create_dialog_req_nocontact() function is similar to sip_create_dialog_req(), except that it does not add the contact header.
Return Values
The sip_create_dialog_req() and sip_create_dialog_req_nocontact() functions return the resulting SIP message on success and NULL on failure.
The value of errno is not changed by these calls in the event of an error.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
libsip(3LIB), attributes(5)
