man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_create_empty_oid_set(3GSS)
Name
gss_create_empty_oid_set - create an object-identifier set containing no object identifiers
Synopsis
cc [ flag... ] file... –lgss  [ library... ]
#include <gssapi/gssapi.h>
OM_uint32 gss_create_empty_oid_set(OM_uint32 *minor_status,
     gss_OID_set *oid_set);
Description
The gss_create_empty_oid_set() function creates an object-identifier set containing no object identifiers to which members may be subsequently added using the gss_add_oid_set_member(3GSS) function. These functions can be used to construct sets of mechanism object identifiers for input to gss_acquire_cred(3GSS).
Parameters
The parameter descriptions for gss_create_empty_oid_set() follow:
minor_status
Mechanism-specific status code
oid_set
Empty object identifier set. The function will allocate the gss_OID_set_desc object, which the application must free after use with a call to gss_release_oid_set(3GSS).
Errors
The gss_create_empty_oid_set() function may return the following status codes:
GSS_S_COMPLETE
Successful completion
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Safe
See also
gss_acquire_cred(3GSS), gss_add_oid_set_member(3GSS), gss_release_oid_set(3GSS), attributes(5)
Developer’s Guide to Oracle Solaris 11 Security
