man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
ldap_first_searchobj(3LDAP)
Name
ldap_searchprefs, ldap_init_searchprefs, ldap_init_searchprefs_buf, ldap_free_searchprefs, ldap_first_searchobj, ldap_next_searchobj - LDAP search preference configuration routines
Synopsis
cc [ flag... ] file... -lldap [ library... ]
#include <lber.h>
#include <ldap.h>
int ldap_init_searchprefs(char **file,
     struct ldap_searchobj ***solistp);
int ldap_init_searchprefs_buf(char **buf, unsigned longlen,
     struct ldap_searchobj **solistp);
struct ldap_searchobj **ldap_free_searchprefs
     (struct ldap_searchobj **solist);
struct ldap_searchobj **ldap_first_searchobj
     (struct ldap_seachobj **solist);
struct ldap_searchobj **ldap_next_searchobj
     (struct ldap_seachobj **solist, struct ldap_seachobj **so);
Description
These functions provide a standard way to access LDAP search preference configuration data. LDAP search preference configurations are typically used by LDAP client programs to specify which attributes a user may search by, labels for the attributes, and LDAP filters and scopes associated with those searches. Client software presents these choices to a user, who can then specify the type of search to be performed.
ldap_init_searchprefs() reads a sequence of search preference configurations from a valid LDAP searchpref configuration file. See ldapsearchprefs.conf(4) . Upon success, 0 is returned and solistp is set to point to a list of search preference data structures.
ldap_init_searchprefs_buf() reads a sequence of search preference configurations from buf, whose size is buflen. buf should point to the data in the format defined for an LDAP search preference configuration file. See ldapsearchprefs.conf(4). Upon success, 0 is returned and solistp is set to point to a list of search preference data structures.
ldap_free_searchprefs() disposes of the data structures allocated by ldap_init_searchprefs().
ldap_first_searchpref() returns the first search preference data structure in the list solist. The solist is typically obtained by calling ldap_init_searchprefs().
ldap_next_searchpref() returns the search preference after so in the template list solist. A NULL pointer is returned if so is the last entry in the list.
Errors
ldap_init_search_prefs() and ldap_init_search_prefs_bufs() return:
LDAP_SEARCHPREF_ERR_VERSION
**buf points to data that is newer than can be handled.
LDAP_SEARCHPREF_ERR_MEM
Memory allocation problem.
Attributes
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/library
Interface Stability
Committed
See also
ldap(3LDAP), ldapsearchprefs.conf(4) , attributes(5)
Yeong, W., Howes, T., and Hardcastle-Kille, S., “Lightweight Directory Access Protocol”, OSI-DS-26, April 1992.
Howes, T., Hardcastle-Kille, S., Yeong, W., and Robbins, C., “Lightweight Directory Access Protocol”, OSI-DS-26, April 1992.
Hardcastle-Kille, S., “A String Representation of Distinguished Names”, OSI-DS-23, April 1992.
Information Processing - Open Systems Interconnection - The Directory, International Organization for Standardization. International Standard 9594, (1988).
