Rack Task
Installation Overview
Follow these general steps when installing a rack at an installation
site.
1. |
Review all safety warnings and guidelines. |
2. |
Determine if you have the original or enhanced
rack. |
3. |
Review the rack dimensions and requirements. |
4. |
Prepare the installation site. |
5. |
Unpack and install the rack. |
6. |
Install PDUs into the rack, if not already installed
at the factory. |
Otherwise, refer to the Sun Rack
II Power Distribution Units User's Guide, or your third-party
PDU documentation, for instructions. |
7. |
Install and cable rackmountable equipment into
the rack. |
8. |
Install the optional components. |
