Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Servicing the Top Panel
The rack has an opening in the top panel, toward the rear of the rack, to allow power and data cables to be routed through. However, for additional equipment, ventilation, or cabling needs, you can remove the top panel.
Two types of top panels are available for the rack. Determine which type of panel you have for appropriate instructions. See Understanding Top Cable Window Dimensions.
Related Information
