Sun Rack
II 1042 Dimensions
Note - Adjusting the RETMA rails can make the rack less stable.
If you adjust the RETMA rails, always install the equipment after
you place the rack at the installation site. Do not move the rack
after installing the equipment.
1 |
Depth from front door handle to rear door
handle |
1058.2 mm |
41.66 in. |
2 |
Distance from rear of rack to opened rear
door |
590 mm |
23.23 in. |
3 |
Depth with doors removed |
970.2 mm |
38.20 in. |
4 |
Distance from front of rack to opened
front door |
638 mm |
25.12 in. |
5 |
Depth with doors opened |
2204.2 mm |
86.78 in. |
6 |
Width |
600 mm |
23.62 in. |
7 |
Height |
1998 mm |
Rack units (RU) |
42 RU (1867 mm) |
42 RU (73.5 in.) |
Depth
Depth between front and rear RETMA rails
685.8 mm
Adjustable from 615.8 mm to 825.8 mm |
27 in.
Adjustable from 24.24 in. to 32.5 in. |
Rear Access |
Maintenance access requirement for rear
914 mm |
36 in. |
Top Access |
Maintenance access requirement from top |
914 mm |
36 in. |
