Two-Piece
Top Panel With Air Brushes
The two-piece top cable window with the air brushes at the
opening is made up of a smaller panel that fits under the lip of
the larger panel. The removal of the smaller panel provides a larger
opening for routing cables out of the rack. The dimensions of these
openings are the same for both the Sun Rack II 1042 and Sun Rack
II 1242.
1. |
Distance between the PDU faces in the
rack. |
504.5 mm |
19.86 in. |
2. |
Width of the top cable window. |
436.626 mm |
9.251 in. |
3. |
Distance from the rear of the rack to
the edge of the top cable window. |
436.626 mm |
17.19 in. |
4. |
Depth of the top cable window. |
130.048 mm |
5.12 in. |
