Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Remove the Top Panel
  1. If necessary, power off the rack.
    See Power Off the Rack.
  2. Open the front door and disconnect the grounding strap connected to the top panel.
    The grounding strap can be found near the top front of the rack. Disconnect the strap by pressing down on the tab of the strap's quick-release connector and pulling the strap away from the connector.
  3. Using a No. 2 screwdriver, remove the five No. 2 Phillips screws securing the support brace to the rack.
    • The first figure shows how to remove the two-piece top panel.
    • The second figure shows how to remove the single-piece top panel.
    image:Figure showing how to remove the two-piece top                                     panel.
    image:Figure showing how to remove the single-piece top                                 panel.
  4. Lift the support brace up and off the rack.
  5. Carefully lift the top panel up and off the rack.
