Equipment
Installation Task Overview
Follow
these general
steps when installing equipment into the rack.
1. |
Follow all safety guidelines for the
rack and the equipment. |
2. |
Extend the antitilt legs. |
3. |
Attach an antistatic wrist strap. |
4. |
(Optional) Adjust the RETMA rails, if
needed for your equipment. |
5. |
Prepare factory-installed PDUs by removing shipping
screws and routing cords.
Or, install PDUs into the rack, if not already
installed at the factory. |
Refer to the Sun
Rack II Power Distribution Units User's
Guide, or your third-party PDU
documentation, for instructions. |
6. |
Install and cable the component into
the rack, using cage nuts and cable management hooks when needed. |
Refer to the equipment documentation
for the installation instructions, plus:
7. |
Prepare to service equipment in the rack. |
8. |
(Optional) To improve air flow through
the rack, install filler panels over any open slots. |
Refer to the equipment or system documentation for the specific
instructions on installing and servicing the equipment into the
rack. Most equipment include a Rack Alignment
Template, which provides specific rackmounting instructions.
For additional instructions, refer to the product installation guide
or rackmounting guide.
Select the appropriate rack for the equipment you plan to
install. For large equipment, or equipment that requires a large
amount of space for cabling, select the deeper Sun Rack II 1242.
Ensure that your installation adequately protects equipment
from excessive vibration and shock. Do not attach external devices
or machinery to the rack that create excessive vibration. The vibration
can damage sensitive equipment installed inside the rack.
Note - Equipment weighing 36.2 Kg (80 lb) or more must be installed
within the bottom 10 U (445 mm/17.5 in.) of the rack.
Note - Ensure that installed equipment or cables do not impede
the air flow through the rack.
Note - Never exceed the maximum allowable weight of installed
