These steps provide general instructions for servicing equipment in the rack. Always refer to the equipment documentation for specific instructions.
Caution - To reduce the risk of personal injury or damage to the equipment, always load the heaviest item first from the bottom of the rack up. This arrangement makes the rack bottom-heavy and helps prevent the rack from becoming unstable. |
Caution - To reduce the risk of personal injury, ensure that the rack is adequately stabilized before extending a component outside the rack. A rack might become unstable and tip over if more than one component is extended for any reason. |
Refer to the equipment documentation for the specific instructions.
You might not need to power off the rack to service installed equipment. However, if you need to power off the rack, see Power Off the Rack for instructions.
See Extend the Antitilt Legs for instructions.
See Attach an Antistatic Wrist Strap for instructions.
Refer to the equipment service manual, or other documentation, for the specific service procedures.
