Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Airflow Precautions
Caution
Caution  - Proper airflow is essential for keeping the equipment's internal temperatures within a safe operating range.
Air flows from the front to the rear of the equipment.
image:A figure showing the direction of airflow through the server.
Follow these guidelines to ensure unrestricted airflow in the equipment:
  • Adhere to the minimum airflow clearance specifications. See Packaging Dimensions.
  • Install the equipment so the front faces the cool aisle and the rear faces the warm aisle.
  • Do not direct warm air into the equipment.
  • Prevent recirculation of air within the rack.
  • When servicing equipment internal components, ensure that air ducts, baffles, and filler panels are properly installed.
  • Route cables so they do not interfere with airflow.
Related Information
