Sun Rack
II 1242 Dimensions
Note - Adjusting the RETMA rails can make the rack less stable.
If you adjust the RETMA rails, always install the equipment after
you place the rack at the installation site. Do not move the rack
after installing the equipment.
1. |
Depth from front door handle to rear
door handle |
1200 mm |
47.24 in. |
2. |
Distance from rear of rack to opened
rear door |
590 mm |
23.23 in. |
3. |
Depth with doors removed |
1112 mm |
43.78 in. |
4. |
Distance from front of rack to opened
front door |
638 mm |
25.12 in. |
5. |
Depth with doors opened |
2340 mm |
92.1 in. |
6. |
Width |
600 mm |
23.62 in. |
7. |
Height |
1998 mm |
78.66 in. |
Rack Units |
Rack units (RU) |
42 RU (1867 mm |
42 RU (73.5 in.) |
Depth
Depth between front
and rear
RETMA rails |
685.8 mm
Adjustable from 615.8 mm to 825.8 mm. |
27 in.
Adjustable from 24.24 in. to 32.5 in. |
Rear Access |
Maintenance access
requirement for rear |
914 mm |
36 in. |
Top Access |
Maintenance access requirement from top |
914 mm |
36 in. |
