Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Standard PDU Physical Specifications
Table 2  Standard PDU Physical Specifications
Dimension
Measurement
Length
1674 mm / 65.91 in.
Depth
47 mm / 1.85 in.
Width
134 mm / 5.28 in.
Power input lead cord nominal length
4 m / 13.12 ft.
Weight (including cords)
Low-voltage PDUs for North and South America, Japan, and Taiwan:
  • 5 kVA, single phase
13.25 kg / 29.21 lbs
  • 10 kVA, single phase
15.00 kg / 33.07 lbs
  • 15 kVA, single phase
16.75 kg / 36.93 lbs
  • 15 kVA, three phase
13.60 kg / 29.98 lbs
  • 24 kVA, three phase
15.70 kg / 34.61 lbs
  • 37 kVA, three phase
17.80 kg / 39.24 lbs
High-voltage PDUs for EMEA and APAC:
13.10 kg / 28.88 lbs
14.70 kg / 32.41 lbs
16.30 kg / 35.94 lbs
16.10 kg / 35.49 lbs
  • 22 kVA, single phase
20.60 kg / 45.42 lbs
25.15 kg / 55.45 lbs
Note -  1 to 1.5 m (3.3 to 4.9 ft.) of the cords will be routed within the rack cabinet, so the site's AC power receptacle must be within 2m (6.6 ft.) of the rack.
