Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
PDU Events List Parameters
Table 40  PDU Event List Parameter (get Command) Available Starting with FW 2.01
Parameters
Syntax
Description
pdu_event_list
pducli -> get pdu_event_list-xx (with option xx is max. number of event for CLI output, without option xx -> default = 10 events)
pducli-> pdu_event_list=E1: yyyy.mm.dd/hh:mm:ss/ xxxxxxxxyyyy.mm.dd/hh:mm:ss/ xxxxxxxx
(with yyyy.mm.dd is date, hh:mm:ss is time and xx is event info)
Note -  A maximum of 1000 events can be handled from a PDU.
Table 41  PDU Event List Parameter (set Command) Available Starting with FW 2.02
Parameters
Syntax
Response
pdu_clear_event_list
pducli -> set pdu_clear_event_list=yes
pducli-> set OK (or an error message)
