Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Monitor the Enhanced PDU (SSH)
Using the metering unit's SSH interface, you can monitor the power, energy, and current being used by equipment attached to the PDU and voltage powering the equipment.
  1. Connect an Ethernet cable between the NET MGT and the host.
  2. Configure the SSH application with the PDU IP address.
  3. When prompted, log in as an admin or user.
    See Login Information.
  4. Familiarize yourself with CLI command options.
    See Understanding CLI Commands.
