Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Install a Compact PDU
  1. Insert the PDU's standoff bolts into the side mounting bracket's keyhole slots.
    Press down on the top of the PDU to ensure that the PDU rests securely in the side mounting bracket.
    image:Figure showing how to install the compact PDU to the side                                 mounting bracket and then secure the top mounting bracket to the                                 frame with a screw.
  2. Using a T-25 Torx wrench key, secure the top mounting bracket to the rack by tightening an M5 screw with a washer to the spring nut you installed in Prepare to Install a Compact PDU.
  3. Using a T-25 Torx wrench key, secure the grounding strap to the PDU with a screw and a washer.
  4. Insert a spring nut into the rack frame channel parallel to the PDU, approximately in the middle of the PDU.
  5. Using a T-25 Torx wrench key, secure the grounding strap connector to the spring nut with a screw and a washer.
    image:Figure showing how to install the grounding strap connector to                                 the rear rail, and how to connect the strap to the                                 connector.
  6. Connect the loose end of the PDU grounding strap to the connector you installed in the rack frame.
  7. Route the power input lead cords between the rear RETMA rail and the side panel.
    A PDU has one power input lead cord, which you must route between the side panel and the rear RETMA rail.
    Route the power input lead cord either down through the bottom of the rack, or up through the top of the rack, depending on where you plan to connect them to the main power source.
    If you are routing the cables through the bottom of the rack, refer to the Sun Rack II User's Guide for the dimensions of the floor cutout.
    Caution
    Caution  -  Never twist, kink, or tightly bend a power input lead.
    Routing Compact PDU cables through the bottom of the rack.
    image:Figure showing how to route the Compact PDU power cord down                                 through a cutout on the bottom of the floor.
    Routing Compact PDU cables Up through the top of the rack.
    image:Figure showing how to route the power input lead cord up                                 through the top window of the rack.
