Enable and Configure SNMP (Enhanced PDU)
Use
the
HTML
interface to enable SNMP, NMS community hosts, and SNMP
users.
Note -
Screenshots with the reset functionality are from FW version 2.01. The
reset functionality is not available beginning with FW version 2.02.
Access the PDU metering unit from a system on the network.
See Access a Metering Unit on the Network (Enhanced PDU).
Click on the Net Configuration link and log in as an admin user.
See Login Information.
Select the SNMP-Access tab.
Click the
SNMP v1/v2, or v3 Enable checkbox to enable SNMP.
If desired, you can disable
HTTP access to the PDU by deselecting the HTTP enable checkbox
on the HTTP-Access tab of the Net Configuration page.
 | Caution -
If you disable HTTP, you are no longer be able to log in to the HTML
interface using a web browser. To re-enable
HTTP access, you can use your SNMP agent software. Refer to
the SNMP agent documentation or the Oracle Solaris
snmpset(1M) man page for more information. You
can also use the CLI command to re-enable HTTP, pducli -> set
net_web_version=1 or 2 (1 for HTTP, 2
for HTTPS.).
Select the appropriate MIB and click submit.
The enhanced PDU is the default MIB setting.
Define up to four NMS hosts on the network for SNMP v1/v2 then click
submit.
A network management station (NMS) host runs network management
applications that monitor and control SNMP-managed devices. NMS hosts
provide the resources required for network management.
Define up to 10
SNMP v3
users then click submit.
For each user select security level, auth algorithm, privacy
algorithm, access type, and then check the enable box to enable this
user.
See Step 4 in Add Users and Change Passwords (Enhanced PDU).
