Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Restore the PDU to Factory Default Settings (RS-232)
  1. Connect an RS-232 cable between the SER MGT port and the host.
  2. Configure the host's terminal or terminal emulator.
    See Terminal Configuration Settings.
  3. When prompted, log in as an admin user.
    See Login Information.
  4. After successful login, type.
    pducli -> factory_default=yes
