Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Adjust the LCD Screen (Enhanced PDU)
You can adjust the LCD screen orientation and background to help you view the screen within the rack.
  • Press and hold the Select Attribute button until the LCD screen rotates 90 degrees.
    Continue to press and release the Select Attribute button to cycle through different LCD screen orientations. The first four screens have black text on a white background, while the other four have white text on a black background. The final selected screen becomes the new default orientation.
    image:Figure showing how you can rotate the LED screen in 90-degree                                 intervals.
