Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Reset the PDU Metering Unit (Original PDU)
You can reset the PDU metering unit using the reset button.
Note -  Resetting the metering unit does not power cycle equipment attached to the PDU.
  1. Press and hold the reset button until you see a five-second countdown displayed on the LCD screen.
    You must press the reset button for 20 seconds before the five-second countdown begins.
    image:Figure showing how to press the reset button until the PDU                                 resets.
  2. During the five-second countdown, release the reset button and then tap the button again to force the metering unit to reset.
