Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Compact PDU Physical Specifications
The following table list the physical dimensions for both types of compact PDUs.
Table 7  Compact PDU Physical Dimensions
Dimension
5 kVA Low-Voltage PDU
5 kVA High-Voltage PDU
Length
430 mm / 16.93 in.
430 mm / 16.93 in.
Depth
47 mm / 1.85 in.
47 mm / 1.85 in.
Width
134 mm / 5.28 in.
134 mm / 5.28 in.
Power input lead cord nominal length
4 m / 13.12 ft.
4 m / 13.12 ft.
Weight (including cords)
5.0 kg / 11.0 lbs
5.0 kg / 11.0 lbs
Note -  1 to 1.5m (3.3 to 4.9 ft.) of the cords will be routed within the rack cabinet, so the site's AC power receptacle must be within 2m (6.6 ft.) of the rack.
