Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Preparing for Installation
These PDUs are designed exclusively for the Sun Rack II family of rack cabinets. Install the PDUs into the Sun Rack II cabinets before installing other equipment. Refer to the Sun Rack II User's Guide for information about installing equipment into the cabinets.
Note -  The three-phase standard PDUs (both the high-voltage and low-voltage versions) are not supported in the Sun Rack II 1042. If your equipment requires a three-phase PDU, use the Sun Rack II 1242 instead.
