Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: December 2016
Restoring the PDU to Factory Default Settings (Enhanced PDU)
If you need to correct a configuration error, or you want to clear the PDU before moving it to a different rack, you can restore the PDU metering unit back to its factory settings.
After restoring the unit, all network and configuration settings reset back to their default values (for example, admin is the only user and the IP address returns to 0.0.0.0 with DHCP enabled). All settings that you set for your environment are lost.
Note -  After restoring the PDU metering unit back to its factory settings, you must reconnect it to the network. See Connecting Standard PDUs to the Network for instructions.
