This rackmount kit includes the multi-piece CMA. If your rackmount kit includes the CMA comb, see Rackmount Kit (Part number 7069640)
The rackmount kit has two shelf rails, one for each side of the rack. Each shelf rail is marked LEFT or RIGHT.
The shelf rails are mounted to the rack with four adapter brackets. The shelf rails adjust to fit rack depths from 25 to 34.25 in. (63.5 to 87 cm).
