Go to main content
SPARC T5-8 Server Installation Guide
Exit Print View
Updated: October 2015
Installing the CMA
The cable management assembly is an optional kit for managing and routing power and data cables attached to the back of the server. There are two types of CMAs and rail kits. Determine which type you have for applicable installation instructions.
Note -  This server with the multi-piece CMA (part number 7041990) attached will fit only into a 1200-mm rack.
These topics provide the information and tasks needed to install the CMA:
Related Information
