NET MGT Port
The NET MGT RJ-45 port, located on the rear panel, provides an optional Ethernet connection to
the SP. The NET MGT port is an optional connection to the Oracle ILOM on the SP. The SP NET MGT port
uses an RJ-45 cable for a 10/100BASE-T connection. If your network does not use a DHCP server, this
port will not be available until you configure network settings through the SER MGT port. See Rear Panel Components
(Installation).
1
Transmit Data +
5
Common Mode Termination
2
Transmit Data –
6
Receive Data –
3
Receive Data +
7
4
8
