Electrical Specifications (Half Populated)
Voltage range
200 to 240 VAC
Frequency
50 to 60 Hz
Maximum operating input current at 200 VAC
(Actual amperage draw may exceed rating by no more than 10%)
30A (16A per cord)
Maximum operating input power at 200 VAC
(Actual power draw may exceed rating by no more than 10%)
6000W
Maximum standby power
260W
Idle input power (maximum configuration)
1540W
Idle input power (minimum configuration)
1200W
Peak AC input power (maximum configuration)
3680W
Conforms to SpecJBB
Peak AC input power (minimum configuration)
3200W
Conforms to SpecJBB
Maximum heat dissipation
22,185 BTU/hr 23,405 KJ/hr
 | Caution -
Use only the power cords provided with the server.
For information on power specifications, use the power calculator at:
http://www.oracle.com/us/products/servers-storage/sun-power-calculators
