Prepare the power cords by routing them from the AC power source to the server.
![]() | Caution - Use only the power cords provided with the server. |
![]() | Caution - Do not attach power cables to the power supplies until you have connected the server to a serial terminal or a terminal emulator (PC or workstation). The server goes into Standby mode and the Oracle ILOM on the SP initializes as soon as a power cable connects a power supply to an external power source. System messages might be lost after 60 seconds if a terminal or terminal emulator is not connected to the SER MGT port before power is applied. |
Do not attach the power cords to the power supplies at this time.
