USB Ports
Two USB 3.0 ports are located at the rear panel. Two additional USB 3.0 ports are located on
the main module and are accessible from the front panel. See the location of the USB ports at Front Panel Components (Installation) and
Rear Panel Components
(Installation). The USB ports support hot-plugging. You can connect and disconnect USB
cables and peripheral devices while the server is running without affecting server
operations.
A1
+5 V (fused)
B1
+5 V (fused)
A2
USB0/1-
B2
USB2/3-
A3
USB0/1+
B3
USB2/3+
A4
Ground
B4
Ground
