The SER MGT RJ-45 port, located on the rear panel, provides an TIA/EIA-232 serial Oracle/Cisco standard connection to the SP. This port is the default connection to Oracle ILOM on the SP. For DTE to DTE communications, you can use the supplied RJ-45 to DB-9 crossover adapter with a standard RJ-45 cable to achieve the required null modem configuration. See Rear Panel Components (Installation).
An additional SER MGT port is located on the main module, and is accessible from the front panel. See Front Panel Components (Installation).
