Connect a Terminal or Emulator
to the SER MGT Port
Prior to powering on the server for the first
time, make a serial connection to the SP from a terminal or terminal
emulator. After making this serial connection, you will be able
to view the system messages when you connect the power cords.
- Confirm
that you have completed the following tasks:
- Completed the preparation for installation.
See Preparing for Installation.
- Completed the installation of the server in a rack.
See Installing the Server.
- Connected the necessary cables.
See Connecting the Server Cables.
- Connect a terminal or a terminal
emulator (PC or workstation) to the server SER MGT port.
- Configure a terminal or terminal
emulator with these settings:
- 9600 baud
- 8 bits
- No parity
- 1 stop bit
- No handshake
A null modem configuration is needed, meaning the transmit
and receive signals are reversed (crossed over) for DTE to DTE communications.
You can use the supplied RJ-45 crossover adapters with a standard
RJ-45 cable to achieve the null modem configuration.
Note - If you power on the server for the first time and do
not have a terminal or terminal emulator (PC or workstation) connected
to the SER MGT port, you will not see system messages.
- (Optional) Connect an Ethernet
cable between the server's NET MGT port and the network to which
future connections to the SP and host will be made.
Configure the system for the first time through the SER MGT
port. After the initial configuration, you can set up communication
between the SP and host through this Ethernet interface.
- Connect an Ethernet cable between
one of the server's NET ports and the network to which the server
will communicate.
- Connect the power cords to the power supplies and to separate power sources.
When the power cords are connected, the SP initializes and
the power supply LEDs illuminate. After a few minutes, the SP login
prompt is displayed on the terminal device. At this time, the host
is not initialized or powered on.
- Continue with the installation
by powering on the server for the first time.
See Power on the System for the First Time.
