Go to main content
SPARC T5-8 Server Installation Guide
Exit Print View
Updated: October 2015
Secure Cables Using the CMA
Use the CMA to secure cables and ensure proper cable routing.
  1. Remove the CMA cover.
    The CMA cover is secured with two No. 2 Phillips screws.
    image:Illustration showing how to use the CMA comb.
  2. Place the system cables into the appropriate slots in the CMA.
    See Connecting the Server Cables.
  3. Install the CMA cover.
    Secure the cover using two No. 2 Phillips screws.
Related Information
