Electrical Specifications (Fully Populated)
Voltage range
200 to 240 VAC
Frequency
50 to 60 Hz
Maximum operating input current at 200 VAC
(Actual amperage draw may exceed rating by no more than 10%)
30A (16A per cord)
Maximum operating input power at 200 VAC
(Actual power draw may exceed rating by no more than 10%)
6000W
Maximum standby power
260W
Idle input power (maximum configuration)
2740W
Idle input power (minimum configuration)
2340W
Peak AC input power (maximum configuration)
6060W
Conforms to SpecJBB
Peak AC input power (minimum configuration)
5520W
Conforms to SpecJBB
Maximum heat dissipation
22,185 BTU/hr 23,405 KJ/hr
 | Caution -
Use only the power cords provided with the server.
For information on power specifications, use the power calculator at:
http://www.oracle.com/us/products/servers-storage/sun-power-calculators
