Go to main content
SPARC T5-8 Server Installation Guide
Exit Print View
Updated: October 2015
Rackmount Kit (Part number 7069640)
This rackmount kit includes the CMA comb. If your rackmount kit includes the multi-piece CMA, see Rackmount Kit (Part number 350-1662-02).
The rackmount kit has two shelf rails, one for each side of the rack. Each shelf rail is marked LEFT or RIGHT.
The shelf rails are mounted to the rack or rack with four adaptor brackets. The shelf rails adjust to fit rack depths from 25 to 34.25 in. (63.5 to 87 cm).
image:Illustration showing the rackmount kit.
No.
Description
1
Top rear brace (right and left)
2
Shelf rails
3
Bottom rear shipping brace
4
Adapter bracket (for square mounting holes)
5
Adapter bracket (for round mounting holes)
6
M6 16-mm screws (16)
7
Cage nuts (4)
8
10-mm screws (12)
9
Guide pin (2)
10
M6 12-mm screws (16)
11
M4 Flathead screws (4)
12
M6 16-mm screws (12)
Related Information
