Connect the Ethernet Network Cables
The server has four network connectors marked NET0, NET1, NET2, and NET3. Use these ports to
connect the server to the network. The Ethernet interfaces operate at 100 Mbps, 1000 Mbps, and 10000
Mbps. See Rear Panel Components
(Installation) for port locations.
Note -
The Oracle ILOM sideband management feature enables you to access the SP using one of these
Ethernet ports. Refer to the administration guide for your server for instructions.
Note -
To achieve 1-GbE network speeds, use Category 6 (or better) cables and network devices that
support 1000BASE-T networks.
Connect a Category 5 (or better) cable from your network switch or hub to Ethernet Port 0
(NET0) on the rear of the chassis.
Connect Category 5 (or better) cables from your network switch or hub to the remaining
Ethernet ports (NET1, NET2, NET3) as needed.
