| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
Gateway Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
This figure provides an example of the IB Performance tab.
The IB Performance tab displays the status of the I4 switch chip ports. A table describes this information:
Connector – Rear panel connector respective to the I4 switch chip port
I4 Port – Port of the I4 switch chip
Link Status – Present link state of the that port. Either Down (yellow) or Active (green)
RX B/w (Gbps) – Instantaneous receive link bandwidth for that port
TX B/w (Gbps) – Instantaneous transmit link bandwidth for that port
By clicking Show Chart, a sixth column for the table is displayed:
B/W (Gbps) – Running bandwidth of the link for that port (0 to 40 Gbps)
Note - You must select the Poll I4 checkbox (default) in the control panel to populate the table with current information.
When displaying the B/W (Gbps) column, the added resource demand on the management controller slows its ability to display the information. Clicking Hide Chart removes the bandwidth charts.
By clicking on a column heading, the information in the table is sorted according to that column heading, either in ascending or descending order. For example, clicking the I4 Port heading sorts the information in the table according to the numeric sequence of the I4 ports. Clicking the Link Status heading sorts the information in the table according to the state of the links.
