| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
Gateway Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Left of the gateway connection rectangles are the BX indicators, which display the status of the BridgeX chip to I4 switch chip connection.
Note - Clicking on the gateway connector name, 0A, 1A, 0B, 1B, either hides or reveals the respective BX indicators. If the BX indicators are not displayed, click on a gateway connector name.
The indicators are labeled BX_0 for connectors 0A and 0B, and BX_1 for connectors 1A and 1B.
This table describes the BX indicators.
Moving the mouse cursor over a BX indicator opens a small window that provides information about the BridgeX port. If the indicator is red, then the window displays a reason for the respective state.
This figure provides an example of moving the mouse cursor over the red upper indicator for port BX_0.
Clicking on a BX indicator opens the BridgeX port status window for that BridgeX port. This figure provides an example of a BridgeX port status window.
At the top of the window are the BridgeX chip name, the respective BridgeX port, and the attached I4 switch chip port. There are two sets of information in the window, one set for the I4 switch chip port, and another set for the BridgeX port. Each set provides this information about the respective port:
Device name and type
GUID, LID, and respective port
Link status and quality
Symbol errors
Recovery errors
Errors of various categories
Throughput statistics
Clicking Close dismisses the BridgeX port status window.
