| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
The rear panel diagram displays four gateway receptacles, labeled 0A, 1A, 0B, and 1B. When a connector is physically present in a gateway receptacle, the receptacle changes from a black rectangle to a gray rectangle with four indicators. Each indicator represents one of the four possible ports available at the connection.
This table describes the four indicators of the gateway connection rectangle.
Clicking on the connection opens the gateway connector status window for that connector. This figure provides an example of a gateway connector status window.
At the top of the window is the connector name. There are two parts of the window, the cable FRU ID information on the left and a smaller status pane for the ports on the right.
The cable FRU ID information includes:
Identifier
Connector type
Vendor
Vendor OUI
Part number
Revision
Serial number
Date of manufacture
The smaller status pane has tabs for each of the four ports. Clicking on a tab displays that port's information. How the connector has been configured, for Ethernet or Fibre Channel, determines what information is displayed for each port. Typically, the information includes:
Physical status and logical state
Gateway slice (connector) and protocol (speed)
I4 switch chip routing port and gateway routing slice
Additionally, a table provides information about configured VNICs:
ID and MAC address
GUID, device name, and LID
vLAN attachment
State
Clicking Close dismisses the gateway connector status window.
