Go to main content
Oracle® SuperCluster M8 and SuperCluster M7 Administration Guide
Exit Print View
Updated: June 2020
Enable ssctuner
Usually ssctuner is running. If for some reason ssctuner is not running, use this procedure to enable it.
  1. Enable ssctuner.
    # svcadm enable ssctuner
  2. Verify that the ssctuner service started.
    # svcs ssctuner
    If the service does not transition to an online state after a minute or two, check the service log file. See View Log Files.
  3. Check the /var/adm/messages log file to see if ssctuner changed any configuration file settings.
    See View Log Files.
    If configuration settings changed, you must reboot the OS for the changes to take effect. If settings did not change, you do not need to reboot the OS.
Related Information
