Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
Gateway Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
This figure provides an example of the System Info tab.
The System Info tab displays status information regarding the gateway hardware. The information is categorized in these groups:
Service Processor – Basic information about the management controller
Core IB Switch – Basic information about the I4 switch chip
Firmware – Version and build date
Chassis FRU – FRU ID information about the chassis
Power Supply FRU (0) – FRU ID information about the left power supply
Power Supply FRU (1) – FRU ID information about the right power supply
BridgeX (0) – Firmware information about BridgeX chip 0
BridgeX (1) – Firmware information about BridgeX chip 1
If the Poll I4 checkbox in the control panel is selected (default), then you can click Show aggregate bandwidth chart to display the historic total bandwidth. This figure provides an example of the aggregate bandwidth.
Note - The aggregate bandwidth chart has a dynamic time scale. The scale is continually adjusting for the initiation time on the left and the current time on the right.
Clicking Hide aggregate bandwidth chart removes the bandwidth chart.
