Install a Processor Module or Processor
Filler Module
Processor modules are cold-service components
that can be replaced only by qualified service personnel. For the
location of the processor modules, see Front Panel Components.
| Caution - This procedure requires that
you handle components that are sensitive to electrostatic discharge.
This discharge can cause failure of server components. |
- Determine
your first step:
- If you are
installing a processor module after replacing or installing DIMMs,
go to Step 2.
- If you are installing a new processor
module to replace a faulty one, install all of the DIMMs that you
removed from the faulty processor module into the replacement module.
See Install a DIMM.
- Open the latches on the processor
module or processor filler module, and insert the module into the
empty processor module slot in the server.
Note - A processor filler module can only be installed in slot
1.
- Bring the levers together toward
the center of the module and press the levers firmly against the
module to fully seat the module back into the server.
The levers should click into place when the module is fully
seated in the server.
- Power on the server.
See Returning the Server to Operation.
- Verify the processor module functionality.
See Verify the Processor Module.
- If you are adding a second processor
module to the server, return to Server Upgrade Process
