Remove a PCIe Carrier Extension
Normally, it is not necessary to remove a carrier
extension when you are replacing the PCIe card. However, if you
are reconfiguring the server to remove a double-wide carrier, use
the steps in this procedure.
- Remove
the PCIe carrier and carrier extension from the server.
The PCIe carrier and extension are removed as a single unit.
See Remove a PCIe Card Carrier.
- Unlock the carrier extension
at the front panel.
- Hold the latch open, and swing
the carrier extension away from the main carrier.
- Remove the PCIe card from the
main carrier.
See Remove a PCIe Card.
- Determine your next step:
- Set the carrier extension aside,
and install two PCIe card carriers in the slots that were occupied
by the PCIe card carrier and the carrier extension.
See Install a PCIe Card Carrier.
